Difference Between synthesising Array && with.. select
I am synthesising AES encryption algorithm on Virtex-7.
There is something happened, and I would like to understand why it happened that way.
There's a part of the AES called the s-box, which a prescribed values, used to give make a byte substitution, and by that I mean, the s-box takes a byte (call it b0) , looks for the associated value (call it b1) to this byte, and then replace b0 with b1.
I got a design, where this s-box is implemented using ARRAY (0 to 255) of STD_LOGIC_VECTOR(7 downto 0).
I have made some modifications to this part, thus, the s-box now implemented using with.. select statement, which depends as follows
with b0= xxxxxxxx, select b1=yyyyyyyy.
and I used this instead of the array in the design.
In both scenarios, the s-box is synthesised as a LUT, however, this caused a significant power reduction.
Why did this power reduction happen, in spite of the fact the s-box in both cases is synthesised as a LUT?
I am using Vivado 2015.4. and VHDL.
Scholar austin
Re: Difference Between synthesising Array && with.. select
Open the implemented design, and look at it,
Austin Lesea
Principal Engineer
Xilinx San Jose
Thank you, @austin
At what exactly in the implemented design I should look? Forgive me, I am still counted to be new to all of this.
Scholar austin
a,
Or look at the usage report.
How many LUT and of what type? (LUT2, LUT3, LUT4, LUT5, LUT6)
Coding style makes a difference.  Some styles are more resource efficient, some are more power efficient.
How many levels of logic are there between registers? (pipelining)  The more pipelined a design is, the faster it can go.  The faster the clock, the higher the dynamic power.
Austin Lesea
Principal Engineer
Xilinx San Jose
