Digital Clock ( Nexys4 DDR Artix-7 FPGA Board)
I want to make a Digital Clock on FPGA but the segment variable in seven_four.vhd is always "1111111". How the 'sec' variable can be different than '00','01','10' and '11'.
@kaanibis,
1. Show us the complete code; where is counter defined?
2. Use signals, don't use variables.
FPGA enthusiast!
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer solved your problem.
