Disable signal optimization doesn't work in XST
I want to use two signals in order to create a probe with FPGA editor. I have my code in vhdl:
attribute keep: string;
--Some code here
signal within_crc :std_logic := '0';--! FOR TEST ONLY!!
signal within_state : std_logic := '0'; --! FOR TEST ONLY!!
attribute keep of within_crc: signal is "true";
attribute keep of within_state : signal is "true";
But it seems that XST ignore or change their name, and I'm not able to find their nets in FPGA Editor. I looked over the synthesis report, and I only found the following messages relative to the signals:
Set property "KEEP = TRUE" for signal <within_crc>.
Set property "KEEP = TRUE" for signal <within_state>.
I don't know where can be the issue...
Re: Disable signal optimization doesn't work in XST
fdomingues@ulmaembedded.com
Use Save(S) attribute to prevent the nets in synthesis and implementation phases.
Check below links for more details:
https://www.xilinx.com/support/answers/35504.html
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/xst.pdf
Anusheel
Helpful answer -> Give Kudos
Anusheel
