Discrepencies between behavioral simulation and implementation in verilog
I lost 2 days on this problem, now that I found the solution I would like to share  and may be understand if someone knows
This verilog was working nice in behavioral simulation but not in implementation
reg [31:0]         ads_reg[0:20];
wire  [4:0]        addr;
wire
ads_sign;
assign             ads_sign = ads_reg[
addr][31];
This modification is working in implementation
wire  [4:0]        addr;
wire  [31:0]       ads_data;
wire               ads_sign;
assign             ads_data = ads_reg[addr];
assign             ads_sign = ads_data[31];
Similarily this was working nice in behavioral simulation but not in implementation
reg [31:0]         data;
wire  [4:0]        addr;
wire
ads_sign;
always @(posedge clock_proc)
   begin :
   ads_reg[addr][31]<=data[31] ;
   end
 Actually this line ads_reg[addr][31]<=data[31] ; was just like removed! info warning was:
 Xst:2679 - Register <ads_reg<0..21><31>> in unit <motor_regblock> has a constant value of 0 during circuit operation. The register is replaced by logic.
This modification is working in implementation (ok not funktionnaly the same but was ok in my application)
reg [31:0]         data;
wire  [4:0]        addr;
wire
ads_sign;
   begin :
   ads_reg[addr]<=data;
   end
 Hope this helps!
Marcel
Message Edited by mguw on 08-17-2009 02:48 AM
