Does Vivado implement the SUBTYPE attribute correctly?
Consider the following code:
library IEEE; use IEEE.STD_LOGIC_1164.ALL;
entity test is port (output : out std_logic_vector); end;
architecture arch of test is
    signal out_val : output'SUBTYPE := (others => '0');
begin
   output <= out_val;
end;
entity top is port (output : out std_logic_vector(7 downto 0)); end;
architecture top of top is begin
    inst : entity work.test port map(output => output);
end;
This fails with the following error:
[Synth 8-211] could not evaluate expression: OTHERS in array aggregate without constraining context
(and if the default value assignment is ommited it fails with Synth 8-318 instead).
So here's the question.  Who is wrong here, the standard or Vivado?  If this error message is legitimate, ie if output'SUBTYPE really has no constraining range in context, then actually output'SUBTYPE can't be used to declare anything and is therefore pretty useless, and this is a weakness in the standard.  On the other hand, other tools (Questa vsim, in particular) simulate this without problems.
The language of the standard for 'SUBTYPE is a bit opaque:
The fully constrained subtype that is the subtype of O, together with constraints defining any index ranges that are determined by application of the rules of 5.3.2.2. (If O is an alias for an object, then the result is determined by the declaration of O, not that of the object.)
and I don't understand the rules for propagating types into parameters enough to comment, except presumably study of section 5.3.2.2 might answer the question.  Still, if it's a choice between the standard getting it wrong and Vivado, I know where I'd place my bets...
Re: Does Vivado implement the SUBTYPE attribute correctly?
Remarkable.  It looks as if this is actually fixed in 2016.3 (I was testing with 2016.1).  That was ... unexpected.
Hi @araneidae
Which version of Vivado are you using?
I see the following error with 2016.3
ERROR: [VRFC 10-85] subtype is not an attribute
Thanks,Vijay
Sorry, forgot to mention both Vivado version (2016.1 in first message, 2016.3 in second) and VHDL version, which is 2008. This attribute is new to VHDL 2008, hence the doubtful implementation...
Hi @araneidae
It is always recommended to use the latest version for better results. :-)
Thanks,Vijay
