Don't see net on RTL schematic
Hello.
I created my first project and when I view RTL schematic i don't see connection net UART_RXD.
I use ISE 14.7 I go to schematic through
Please help me where I have a mistake or may be need change some settings? Thanks.
Re: Don't see net on RTL schematic
Hi @485337
I have checked that there are multiple warnings related to trimming of certain flops/latches after synthesizing your project design.
Hence, i have untick Equivalent Register Removal property. (As shown below.) and it resolves your issue. It
In Project Navigator go to Process Properties > Xilinx Specific Options > Equivalent Register removal.
It will resolve your issue and shows the UART_RXD as an input of Main module as shown below.
hemangd
Please mark this answer as accepted solution if it resolves the issue at your end.
hemangd
Hi @485337
hemangd
hemangd
Thanks a lot.
