ERROR: [Common 17-1294] Unable to create directory [.../realtime]
I am using Vivado 2018.1 for Kintex-7 devices (mostly 160T/325T -1 devices) and I seem to keep getting this random error now and then when I run synthesis in my projects.
I typically run multiple synthesis runs at a time which I launch using "launch_runs -jobs 4 synth_A synth_B synth_C" and it seems that at least one of them always gives me this error lately.
Has anybody seen this before and know of a solution?
Tim
Re: ERROR: [Common 17-1294] Unable to create directory [.../realtime]
@anusheel / @hemangd,
   Yes, I am using Windows 10 OS.   I have not seen the issue consistently so it is hard to say if it happens with non customized synthesis runs or not.  I suspect it has something to do with launching multiple runs simultaneously.   Also, since I cannot get it to happen every time I do not really have a specific project I can share which is guaranteed to produce the error.
   I was mostly hoping somebody had seen the error before as well and would have some inputs.
Tim
Hi @tim_severance,
Please provide a testcase (archived project) to check the root cause of this issue.
hemangd
hemangd
Don't forget to give kudos and mark it as accepted solution if your issue gets resolved.
@tim_severance
Are you using Windows OS? Can you try to shorten the project path and let us know if that helps.
Also, I can see that you are launching manually created runs, can you try to run default synth_1 created by tool?
Anusheel
Anusheel
Tim
The same just happened to me.
Twice I ran
reset_run synth_IP10
reset_run impl_IP10
launch_runs impl_IP10 -to_step write_bitstream -jobs 2
with different changes in the code,
after a third time, I get this error.
However when I reset manually and let it run from the "buttons" instead of the TCL console, it works.
Strange...
System: Windows 2012, Vivado 2018.1
