Teacher muzaffer
ERROR: [Synth 8-4556] size of variable is too large to handle ...
I have  64x2048 array of 32 bit numbers. I declare an array of this size and initialize it with an array initializer. I expect this to map to block ram (I have the ram_style = block attribute on the array). This simulates with VCS and works properly. I also have another design where a very similar array is mapped to block ram through synthesis. It seems that this is only a size issue and potentially it's an arbitrary number. Is there a way to increase the size synthesis expects to be able to handle?
The actual error is:
ERROR: [Synth 8-4556] size of variable 'mat_lin' is too large to handle; the size of the variable is 4194304, the limit is 1000000
Teacher muzaffer
Re: ERROR: [Synth 8-4556] size of variable is too large to handle ...
It seems the tcl param already exists for this purpose:
set_param synth.elaboration.rodinMoreOptions "rt::set_parameter var_size_limit 4194304"
I didn't see this error before. Which version if Vivado are you using?
Can you please share the testcase?
Thanks,Vijay
Is "mat_lin" an array declaration or signal in your code ?
Do you have any dynamic access on "mat_lin" ?
I don't see an option to change the limit currently, need to check limit based on the variable used in your case.
Share us the design so that we can clarify further.
Achutha
Teacher muzaffer
I am using 2014.4 and there is nothing interesting in the array. Just a straight static array which needs to be mapped to some block rams:
reg[63:0] RAM [2047:0][31:0];
One can split it into smaller pieces but it's a hassle and the limit is reached by using a small percentage of block rams in some devices. Also this array is initialized and the initializer will need to be regenerated by an updated script if the array is split. The limit is simply too low I think.
The limit seen in the error looks like the soft limit.
A CR#841660 is filed to address this.
I will update you on the out come of the CR.
Achutha
Teacher muzaffer
It seems both synplify & xst can manage this size array without any problems so a CR was definitely needed. Thanks to Puli. I wonder what the new limit is going to be.
The limit was set based on some limitation earlier. We may have to wait for the update on the CR to get the new limit or a solution.
I see two options,
1. Fix the limit  and provide a TCL command to change the limit  as this is a soft limit.
2. Increase the memory limit.
Achutha
Teacher muzaffer
Visitor jpleiker
Can you explain where this TCL parameter is set at? Was your 'set_param synth.elaboration.rodinMoreOptions "rt::set_parameter var_size_limit 4194304" ' command entered in a particular file?
This appears to be the solution to increasing the soft limit, I was hoping you could provide some guidance on how to implement it.
Thanks!
Teacher muzaffer
You can just type it into the tcl console in Vivado or add it to your init.tcl
