caratamity
ERROR:Xst:1590
I have the following error while synthesizing/maping my design for Xlinx ML501 board. I am using ISE 10.1 on ubuntu.
ERROR:Xst:1590 - Line 20: Instance name 'ddrsp0.ddrc0/ddr_phy0/ddr_phy0/xc4v.ddr_phy0/idelctrl[0].u' not found in the design
How can I resolve this error. Help me in this regard, please.
Amir
eteam00
Professor
Professor
The error message suggests you are using a Virtex 4 IP (..../xc4v.ddr_phy0/...) for a Virtex 5 target (ML501).
Perhaps there's a reference in your design to a Virtex 4 physical entity or location which doesn't exist in the target Virtex-5 device.
-- Bob Elkind
SIGNATURE:
Summary:
viviany
Can you post the code which is pointed to in the error message? That'll help identifying the problem and solution.
Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
