krish.iitd
ERROR:Xst:2545 - Variable index is not supported in signal.
Hi all,
I am using Xilinx-10.1 design suite and while synthesizing an RTL, XST  tool flags following error:
ERROR:Xst:2545 -"file.v" line 11872: Variable index is not supported insignal.
 for verilog constructs shown below:
abc_w[{abc_C, 2'h0}+:4] = abc_S;
What is the problem here? ASIC sythesis tools like DC/RC has no issue with such constructs.  Is there any workaround for this problem or is there any other tool that can handle such constructs (for synthesizing to Xilinx FPGA)?
Also XST doesn't allow RTL to contain divison operations other than power of 2, so how do we handle divison operations in FPGA?
ERROR:Xst:867 - "file.v" line 474: Operator / is only supported when the second operand is a power of 2.
for RTL constructs
div_ln57_w = {su_w[27:1], m_w[32]} / 3'h7;
Please help.
Krishnaiah
gszakacs
Professor
Professor
I took a look at this and found:
1) "Syntax Check" did not show the error.
2) It seems that the +: syntax is what XST really doesn't like.
    for (i = 0;i < 4;i = i + 1)
      abc_w[{abc_C,2'b00}+i] <= abc_S[i];
synthesized O.K.
Many people use Synplify instead of XST.  There are other third-party synthesis options
as well.
As for division, I would generally avoid it, although you can use CoreGen modules to
implement dividers if necessary.  In the case of dividing by a constant, consider
using multiplication instead.
Gabor
-- Gabor
gszakacs
Professor
Professor
synthesized O.K.
as well.
Gabor
-- Gabor
krish.iitd
Thanks for a quick response.
Since the RTL has so many lines with "+:" operators, I am not sure how to manually change all of them to the way that XST handles. Will Synplify tool be able to handle the constructs with "+:" range specifiers?
gszakacs
Professor
Professor
Synplify for Lattice has no problem with the +: syntax, so I imagine the full Synplify
would also work fine with this syntax.
Gabor
-- Gabor
ywu
XST works fine with the indexed part-select  operator "+:" if it is on the right-hand side (RHS) of the assignment. It also works fine when it is on the left-hand side (LHS) AND the starting index is a constant. Your case uses a variable as the starting index on the LHS and that what XST doesn't like although it's legal.
FWIW, your case should work in 11.2 if you're targeting Virtex6 and Spartan6 as XST uses a new Verilog parser for the two new families.
Cheers,
Jim
Message Edited by jimwu on 07-07-2009 10:22 AM
Cheers,
Jim
kwooding
Curious (and annoying).
Is there any way to force ISE to use the new verilog parser for older families? (e.g. spartan 3A-DSP)? This notation is much more nicely compact
than the alternatives.
Also, are these limitations documented anywhere? All I can find in the XST manual is that Variable Part Selects are "supported" (e.g. summary at the end of Ch 8)
