fingertouch0
ERROR:Xst:872
Hi.
What is the matter of an error:
ERROR:Xst:872 - "module_v.v" line 85: Unsupported target
I didn't find  a record in the Answer Database...
This is my  module:
76                     phy_level #                                                  //used module name
77                          (
78                          .NO_OF_LANES (NO_OF_LANES ),
79                          .NO_OF_GTP_DUALS (NO_OF_GTP_DUALS ),
80                          .NO_OF_INTERTRIGGERS (NO_OF_INTERTRIGGERS ),
81                          .PLL_DIVSEL_FB (PLL_DIVSEL_FB ),
82                          .PLL_DIVSEL_REF (PLL_DIVSEL_REF ),
83                          .CLK25_DIVIDER (CLK25_DIVIDER )
84                           )
85                    phy_level                                                       //Instance name
86                           (
....               //Table of module inout signals
125                         );                                                             //End of Phy_layer instantiation
nc6
sorry i missed that. check out answer record AR# 20433.
regards,
nc6
are you missing a ";" after line 84
probably your code must look like this
84                           );    // you are missing a semicolon here.
85                    phy_level
                                 //Instance name
86                           (
regards.
fingertouch0
No, there mustn't be a semicolon after parameter list.
nc6
regards,
fingertouch0
Thanks, I solved my trouble with AR#20433, solution 2.
carlkopin
where did you find the answer record AR# 20433?
fingertouch0
I dont remember, sorry. The search function on Xilinx website is a problem...
rho88
I know this is a little old topic, but I agree that the searching on the Xilinx website is really bad.  I am also looking for that AR and I searched the exact number and the search didn't find it, it only found this forum post in the search results.  You can also google AR 20433 the first result is the direct link.  To solve this go directly to the answer record.  All you need to do is just modify the URL directly.  For example "http://www.xilinx.com/support/answers/20433.htm"  Just replace 20433 with whatever AR you want
