ERROr:Assignment under multiple single edges is not supported for synthesis
ERROR:HDLCompiler:1128 - "C:\Users\kokomama\Desktop\msa\memory\serial_2_parallel2_slave.v" Line 39: Assignment under multiple single edges is not supported for synthesis
i could not solve this error on the code below
module serial_2_parallel2 #(parameter n= 16)
input [n-1:0] out_mem,
input [2:0] Nvn,
input clk,
input rst,
input validin,
output reg validout,
output reg [n-1:0] LLR_1,
output reg [n-1:0] LLR_2
reg flag;
reg [n-1:0] reg_mem_1;
reg [n-1:0] reg_mem_2;
reg [n-1:0] reg_mem_3;
reg [n-1:0] reg_mem_4;
reg [n-1:0] reg_mem_5;
reg [n-1:0] reg_mem_6;
reg [n-1:0] reg_mem_7;
reg [2:0] j;
reg [2:0] i;
reg [2:0] k;
always@(posedge clk or negedge rst)
begin
if(!rst)
begin
i=0;
j=0;
flag=0;
validout= 0;
end
if (Nvn % 2 == 1 && i== 0) //if odd, add 1
begin
k = Nvn+1;
end
else if (Nvn % 2 == 0 && i== 0) //if even
begin
k = Nvn;
end
if (validin == 1) //reading cycle
begin
case (i)
3'b000 : begin
reg_mem_1 = out_mem;
flag = 1 ;
i = i+1;
end
3'b001 : begin
reg_mem_2 = out_mem;
i = i+1;
end
3'b010 : begin
reg_mem_3 = out_mem;
i = i+1;
end
3'b011 : begin
reg_mem_4 = out_mem;
i = i+1;
end
3'b100 : begin
reg_mem_5 = out_mem;
i = i+1;
end
3'b101 : begin
reg_mem_6 = out_mem;
i = i+1;
end
3'b110 : begin
reg_mem_7 = out_mem;
i = i+1;
end
default
begin
reg_mem_1=0;
reg_mem_2=0;
reg_mem_3=0;
reg_mem_4=0;
reg_mem_5=0;
reg_mem_6=0;
reg_mem_7=0;
end
endcase
end
if (flag && (i > k /2 -1 )) //writing
begin
case (j)
3'b000 : begin
LLR_1 = reg_mem_1;
LLR_2 = reg_mem_2;
flag = 1;
validout = 1;
j = j+1;
end
3'b001 : begin
LLR_1 = reg_mem_3;
LLR_2 = reg_mem_4;
j = j+1;
end
3'b010 : begin
LLR_1 = reg_mem_5;
LLR_2 = reg_mem_6;
j = j+1;
end
3'b011 : begin
LLR_1 = reg_mem_7;
end
default
begin
LLR_1 = 0;
LLR_2 = 0;
end
endcase
end
if ( j == k/2 ) //reset
begin
i=0;
j=0;
flag=0;
validout= 0;
end
end
endmodule
please any help
Re: ERROr:Assignment under multiple single edges is not supported for synthesis
After your "if (!rst)" put an "else" and everything put all the lines in that else statement. ie:
if (!rst) begin
end else begin
... // everything goes here
end
if (!rst) begin
end else begin
end
