Anonymous
Not applicable
Endless synthesis loop ISE - verilog parameter passing
I am using ISE 11.2. I am instantiating a FIFO 9 times in my design. I am passing data width, address width and fifo depth through parameters as each FIFO has different sizes. Instantiation is as follows:
sync_fifo # (35,3,8) sync_cmd_fifo // to store commands for memory after port width adjustment
    .reset(mc_bond_reset),
    .clk(mc_bond_clk),
    .fifo_wr_data(vdc1_scmdf_data_in),
    .fifo_wr(vdc1_scmdf_wr),
    .fifo_rd_data(vdc1_scmdf_data_out),
    .fifo_rd(vdc1_scmdf_rd),
    .fifo_empty(vdc1_scmdf_empty),
    .fifo_full(vdc1_scmdf_full)
With this type of coding, synthesis goes in infinite loop, no warnings or messages shown. It is stuck at translation phase.
But when I instantiate without passing any parameters, as follows:
sync_fifo sync_cmd_fifo // to store commands for memory after port width adjustment
    .clk(mc_bond_clk),
Here I am not passing any parameters, synthesis completes successfully in 2-3 mins. How can I resolve this problem?
gszakacs
Instructor
Instructor
Positional arguments are not considered good practice in general.  Are you sure that the
parameters you are passing are going to the correct underlying parameter in module
sync_fifo?  For example if you think you're making a fifo with data width 35, but the actual
first parameter arguiment is the depth you could run into problems with unsupported
parameter values.
Gabor
-- Gabor
Anonymous
Not applicable
Thanks for your comments. I realised that when I set the fifo_depth to 1024, synthsis goes on for hours, havent seen it end. But if I change it to 8 , synthesis is completed in 2-3 mins. btw, I am using the async fifo design from sunburst.
supatil1
While mapping the parameter you have to to care. You have to avoid positional mapping.
This is common problem in passing parameters
