boomshakalaka
Error [Synth 8-4485] pin is connected to multiply driven net where other driver is constant
Hello,I find a error message in my project :
[Synth 8-4485] pin SW0 is connected to multiply driven net where other driver is constant.
SW0 is an input signal which is defined in top module and it is used in the module "exmemory".
I have not ever assigned a value to SW0.
The part of source code is in attachments.
Thanks for your help.
anusheel
@boomshakalaka
I can see that you are writing the RAM from two always blocks and hence the multi-driver issue, please use below link to check the memory RTL examples:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug901-vivado-synthesis.pdf
Anusheel
Helpful answer -> Give Kudos
boomshakalaka
Thanks for ur advice.
I modify the always blocks but still errors.
Please check the attachments,and I will appericiate it if u can help me.
