Error_design clock consistency
I created a simple adder ip based on option "Create and Package new IP" in vivado, so I am trying to make simple design ( depicted below), in order to laverage partial reconfiguration, but it doesn't have consistency between clocks of IP signals, in below errors are denoted well in image, so do yu have any idea how to solve this issue ? thanks in advance error_design.jpg
@tarek.elouaret
Your custom IP has multiple drivers for a net. Check and fix them before packaging the IP.
--Syed
Hi @syedz Thanks for your reply, the fact, how may I fix them, could yu show me how ? thanks
