Error generate output products: [IP_Flow 19-3286] Unsupported VHDL data type 'INTEGER' for bool value.
I'm doing the design with some vendor IP. I am using Vivado 2017.2 and Windows 10. When I set verilog as target language, everything works well. But if I changed to VHDL, I will get the following errors when generating output products. The error seems sporadic, because sometimes it worked fine. Also it always worked on Linux. I suspect it could be my environment issue. Can someone help?
Here are the errors:
[IP_Flow 19-153] Failed to convert bool value 'false' to HDL value.
[IP_Flow 19-153] Failed to convert bool value 'true' to HDL value.
(16 similar errors within above)
Re: Error generate output products: [IP_Flow 19-3286] Unsupported VHDL data type 'INTEGER' for bool value.
@fengyu.qian,
Can you show us how INTEGER is set or defined in RTL? Found the following related Answer record:
https://www.xilinx.com/support/answers/58038.html
--Syed
@syedz
Thank you for your quick reply.
That answer record help me less...
The problematic IP is in Verilog, and the IP packager defines bool type for some parameters. see the attachment. When Vivado generates the wrapper VHDL for the IP, it seems unable to translate these parameter to 'INTEGERS' as generic,because I don't find these parameter defined in the auto generated VHDL.
This is what I found. Thanks!
@fengyu.qian,
Glad to know the shared answer record helped. Please close this forum thread by marking the post as "Accept as solution"
--Syed
@syedz
No, that didn't help me, I cannot accept it as solution.
Hi @fengyu.qian,
Could you share a test case?
