Error in Viewing RTL Schematic
Thisi is my code created on Xilinx ISE Design Suite 14.5. But when I try to view the RTL Schematic, I get the following error:
Line 9: Signal Ty in unit Timers_Test is connected to following multiple drivers:
I am not able to find the solution to this error.. Please help me.
`timescale 1ns / 1ps
module Timers_Test(st, clk, Ty, Tg);
input st, clk;
output reg Ty;
output reg Tg;
reg [4:0] value=5'b00000;
always@(posedge clk) begin
case(value)
5'b00011:Ty<=1;
5'b10100:Tg<=1;
default: begin
Ty<=0;
Tg<=0;
end
endcase
value<=value+1;
end
always@(posedge st) begin
value<=0;
Ty<=0;
Tg<=0;
end
endmodule
Re: Error in Viewing RTL Schematic
I think the error is pretty clear. You are assigning to Ty in multiple processes so there are multiple drivers. You have the "posedge clk" process and "posedge st" process which are both assigning to Ty and Tg. This will not synthesize.
I think what you want is to be able to detect a rising edge on "st" and make a decision on that event. The event condition "posedge" is not for that purpose, posedge should be used only for inferring flops.
For st what you want is to detect the rising edge by sampling it with a clock ie:
reg st_r;
wire st_posedge = st_r == 0 && st == 1;
  st_r <= st;
  if (value == 5)
    Ty = 1;
  if (st_posedge)
    Ty <= 0;
This will give you a signal which you can use in your "posedge clk" process to make a decision on how to change Ty & Tg as shown.
I could see you are using signal ty,tg in both the process (always block)
that's why you are getting mentioned error.
you can assign signal ty,tg in only one of the always block. If you want to use in both the always block delcare them as a reg
reg ty,tg and use them
Pratham
-Pratham
reg st_r;
  st_r <= st;
  if (value == 5)
    Ty = 1;
  if (st_posedge)
    Ty <= 0;
Thank u, ur solution worked :) ... but why doesnt it work when I declare st_posedge as a reg?
This is an idiosyncrasy of Verilog. You can assign to a reg within a process and wire outside a process (generally). If you have a new-ish simulator, it might allow a new type "logic" to which you can assign in either place.
