Instructor
Instructor
Error initializing memory using $readmemh, Xst:2319 - bug?
I struggled with this for a while but reached an answer by trial and error:
I inferred a 32 x 8 RAM using a simple single-port asynchronous RAM template from
the XST manual.  I initialized it with a $readmemh statement in an initial block.  So
far so good.  During the synthesis I got:
WARNING:Xst:2319 - "../../rtl/fc34_top.v" line 1069: Signal rb_ram in initial block is partially initialized. The initialization will be ignored.
Here's the line in question:
  $readmemh ("rb_mem_init_b.hex",rb_ram); // initialize readback from a file
which is inside an initial block.
The problem is that the ram is 32 x 8 and I had in my file 32 2-digit hex values separated by whitespace
as follows:
 05 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00
11 22 33 44 55 66 77 88
so the ram should be completely initialized, right?
I tried adding a few extra lines to see if XST needed extra bytes.  No good.  Finally I
placed each value on a separate line like:
05
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
11
22
33
44
55
66
77
88
This worked!  However I would have expected the original file to work also.  In my Verilog
reference manual it says that the data entries in the file to be read by $readmemh should
be "separated by whitespace", not specifically newlines.  This seems to be a bug in XST.
I would also consider the behavior of not allowing partial initialization to be a bug as well.
Obviously not initializing the ram at all, which ends up causing the ram to come up all
zeroes after translation, is no closer to matching the simulation result than initializing
the requested portion of the ram and leaving the rest zero or any other value.
Just my 2 cents,
Gabor
-- Gabor
Voyager
Voyager
Re: Error initializing memory using $readmemh, Xst:2319 - bug?
I've found that XST barely supports $readmemh.  Want to add comments to your file?  It won't
work.  Have multiple data items per line?  That won't work.
It really is VERY picky about it's format, and, if it fails, it only puts a warning message in the
.syr file, not an ERROR.  So, if you don't closely examine the .syr file, you might not
notice that synthesis is actually incorrect.
I did a project that had a double buffered ram that I wanted to initialize half of.  XST couldn't
handle that - I had to make the file exactly the same size as the memory.
John Providenza
Instructor
Instructor
I have also seen from other posts that XST won't accept addresses in the
data file, either.  This might be a side-effect of the inability to deal with
partial initialization.  In any case it seems to be a bug.  The least Xilinx could
do would be to document the acceptable data file format.  The XST manual
doesn't mention the file format at all.
-- Gabor
Voyager
Voyager
Yes, Xilinx should document the $readmemh limitations.
It's sad that probably 10 to 20 lines of C code would properly handle this function.
John Providenza
