Error while running implementation through unix command line
I am new to Xilinx and bash scripting. I am using Xilinx 13.4. I am trying to run implementation(ngdbuild, map, par etc) to create the bit file through a bash script, but I am getting an error. Following is the snippet of my error :-
Running synthesis...
bash -c "cd synthesis; ./synthesis.sh"
xst -ifn system_xst.scr -intstyle silent
Running XST synthesis ...
PMSPEC -- Overriding Xilinx file
</tools/Xilinx/13.4/ISE_DS/EDK/virtex5/data/virtex5.acd> with local file
</tools/Xilinx/13.4/ISE_DS/ISE/virtex5/data/virtex5.acd>
XST completed
error status of previous command:0
=> Starting xst: Xst log file is: no_file.syr
Using xst file - no_file.xst
ERROR:Xst:427 - Entry File no_file.xst not found
The file no_file.xst and no_file.syr does not exist in the directory. When I run the process through gui these files get generated but I don't know which command generates those files. I tried to search the web for the error but I have not found a solution.
 Can I get some help on this?
Gaurav.
Also after XST it does not generate .ngc files which are required for ngdbuild. When I run through the gui I am not having this problem though.
