Anonymous
Not applicable
Error!!!!!!
 reg [87:0]Partial1;
reg [21:0]Partial2;
reg [127:0]X;
reg [127:0]Y;
integer i;
always@*
begin
X[87:0]<=Partial1;
for(i=0;i<=21;i=i+1)
begin
Y[4*i]<=Partial2[i];
Y[(4*i+3):(4*i+1)]<=3'b0;
end
Y[127:88]<=0;
end
Errors:
ERROR:HDLCompilers:109 - "Top_Level_Put_Together.v" line 69 Most significant bit operand in part-select of vector reg 'Y' is illegal
ERROR:HDLCompilers:110 - "Top_Level_Put_Together.v" line 69 Least significant bit operand in part-select of vector reg 'Y' is illegal
ERROR:HDLCompilers:106 - "Top_Level_Put_Together.v" line 69 Illegal left hand side of nonblocking assignment
markcurry
Digimax,
Well first of all, you don't want to use non-blocking assignments here.  Change them to
blocking assignments.
Second (Decipering the forums messing up your posting) what you're trying to do in this line:
Y[ (4*i+3) : ( 4*i+1)] = 3'b0;
Isn't legal verilog.  Although you can see that this range is always 3 bits, this
wasn't readily apparant in the original Verilog-XL tools, thus was made illegal.
So, in verilog-2k, you've got new range operators to make these types of things work:
Y[  (4*i+3) -: 3 ] = 3'b0;
  or
Y[  (4*i+1) +: 3 ] = 3'b0;
The key to making this work is that the left side range operator can be variable.
The right side operator - the width - must be constant.
Give this a try, and you should be good to go.
Anonymous
Not applicable
help!!!
shantesh
I'm not familiar with Verilog syntax but did you try Y[127:88] <= 40'b0;
You're assigning a single bit value to a vector !
markcurry
Digimax,
  or
Anonymous
Not applicable
your comments are quite helpful, thank you!
