FATAL_ERROR:Xst:listutil.c:503:1.19 - Data corruption (ListDelShift) - Bad Index Process will terminate.
I had generated HDL code from HDL coder through MATLAB. And I am getting the above mentioned error while synthesis. I had no idea what is the reason behind it and how to resolve it?
Please help!
Re: FATAL_ERROR:Xst:listutil.c:503:1.19 - Data corruption (ListDelShift) - Bad Index Process will terminate.
@pranavstellar
Can you please post the complete log file here?
Anusheel
Here is the Log file @anusheel
Started process "Synthesize".
*                          HDL Compilation                              *
Compiling vhdl file
C:/Xilinx/bin/imcomp2/mlhdlc_fixpt_pkg.vhd in Library work.
Compiling vhdl file C:/Xilinx/bin/imcomp2/../../../Users/hp/Desktop/compression/codegen/mlhdlc/hdlsrc/mlhdlc_fixpt.vhd in Library work.
Architecture rtl of Entity mlhdlc_fixpt is up to date.
*                                      		 HDL Analysis                               *
Analyzing Entity <mlhdlc_fixpt> (Architecture <rtl>).
FATAL_ERROR:Xst:listutil.c:503:1.19 - Data corruption (ListDelShift) - Bad Index   Process will terminate.  To resolve this error, please consult the Answers Database and other online resources at http://support.xilinx.com. If you need further assistance, please open a Webcase by clicking on the "WebCase" link at http://support.xilinx.com
ERROR: XST failed
Process "Synthesize" did not complete.
Pranav !
@pranavstellar
What happens when you synthesize below module as top?
Anusheel
@anusheel
I am working on a project FPGA implementation of Image compression. I had written MATLAB design function for this and it is successfully working in MATLAB.
Then, I had used HDL coder for converting this Matlab function into vhdl code while keeping all the necessary points in mind for conversion.
HDL coder has generated these two files. mlhdlc_fixpt.vhd and mlhdlc_fixpt_pkg.vhd.
When I try to run synthesis in Xilinx project navigator, After almost 3-4 minutes this error gets generated.
Thanks !
Pranav
@pranavstellar
Please let us know the ISE version and device used to compile these files.
Anusheel
@anusheel
Actually I am very new to all these processes. I dont know which version is to be used. But, probably I used ISE 6.1. Screenshot attached for figuring it out.
@pranavstellar
You are using very old tool and that too on unsupported OS platform. Please use latest version on ISE which supports the targeted device:
https://www.xilinx.com/support/answers/15938.html
Anusheel
