maxdz8
Flexibility in next state FSM transition
I'm having plenty of trouble fitting FPGA learning in 1h/day so I guess instead of trashing another week I can ask for a suggestion.
I have an algorithm mangling a 16x16 matrix. I need to build a palette of those which I need to keep around for quite a while. This palette however gets produced in various ways so I need a common 'copy from/to palette storage' function. How would you suggest to implement that? I want to make Vivado inference happy!
I would like to just have a next_fsm_state register. Then, copying to palette would just be a matter of setting it to the right next-state and then setting fsm state to next_fsm_state. I see a problem with this however, all examples I've seen happen to encode fsm next-state transitions to constants. Unless the synthesis is smart in understanding value assignments of next_fsm_state it would have no way to understand what the next state will be out of a 'copy to palette' state. Is that even a problem?
Option number 2.
Have two FSMs (in the same module!), let them be algorithm_fsm and copy_to_palette_fsm. This would allow me to separate/reuse the states. The copy to palette operation would then go in its own function (containing the fsm case) and it could be more easily reused. Is this a better idea?
Bonus question.
I am already reusing a state transition. The way I generate my matrices is like M = g(f(x)). It happens g and f are almost the same thing so to understand if I'm doing g or f I keep a bit and the next state is like:
// example of f~g, yes, they are really this similar
m[0] += 5;
m[1] += 2;
m[14] += fg_bit? (a + b) : (a - b);
m[15] += a << (fg_bit? 1 : 2);
fg_bit = ~fg_bit;
next_state = fg_bit? truly_go_next : do_another_fg;
Is that sensible?
Tags (3)
anusheel
@maxdz8
If the FSM consist of a state register, next state function and an outputs function by keeping coding guidelines in mind, I believe Vivado Synthesis will be able to infer the FSM for you. It would be better if you can paste the RTL code with the results for us to understand the requirement in more details.
To me, the second option of having two separate FSM looks better approach but you can still try the first approach as Vivado should be able to infer the FSM.
Anusheel
anusheel
@maxdz8
Anusheel
maxdz8
Thank you this is still in very early prototyping stages. By better studying the algorithm I've decided to go with two hierarchical FSMs and replicate the copy operation manually for the time being.
