bborko
Generate contents of array (for rom) programmatically
I am creating a ROM that has a generated lookup table but I am having trouble finding syntax for this. This illustrates the idea of what I want to do:
  type ram_type is array (2**ADDR_WIDTH-1 downto 0) of std_logic_vector (DATA_WIDTH-1 downto 0);
  constant GRAPH_LOOKUP_TABLE : ram_type := (
    gen_delta_circle: for theta in 0 to 359 generate
      std_logic_vector(to_signed(to_integer(cos(theta)),DX_WIDTH)) & std_logic_vector(to_signed(to_integer(sin(theta)),DY_WIDTH)),
    end generate gen_delta_circle;
    others => std_logic_vector(to_unsigned(0, DATA_WIDTH))
 --note: data_width == dx_width + dy_width
Does anyone know how to programmatically generate the contents of an array or rom?
thanks!
barryabrown
In VHDL, you can initialize a variable with a function, such as.....
  subtype int18 is integer range -131072 to 131071;
  type mem_array is array(0 to (2**N_addr)-1) of  int18;   -- 4k x 18
  -- function computes contents of cosine lookup ROM
  function init_rom return mem_array is
         (your function here)
  end function init_rom;
  constant rom : mem_array := init_rom;
Barry
