Generating a synthesizable netlist in Viavdo
How do I create a synthesizable netlist from VHDL code so I can give this to a customer and he can't read / modify my VHDL code?
Maybe I don't mean synthesizable netlist, a block box netlist that can be inserted into another design, just a way so the VHDL code can't be read / modified.
I know how to do this in ISE with an NGC file but not sure in Vivado. write_vhdl apparently is for simulation only?
Re: Generating a synthesizable netlist in Viavdo
Hi luis.munoz,
Yes write_vhdl is for simulation netlist file also, but can be used for synthesized netlist too. You can use the write_edif command instead.
After the synthesis of the required module is done in out of context mode, write this command in tcl console:
write_vhdl -mode synth_stub .v
Then write this command in tcl console:
write_edif -security_mode all -force .edn
Now you can simply add the netlist and instantiate it in your project just like any other module
Refer to this document for details on syntax:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug835-vivado-tcl-commands.pdf
Regarding black box requirement: You can simply use black_box attribute in Vivado. Refer below link(page 39):
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug901-vivado-synthesis.pdf
Nupur
Nupur
Hi luis.munoz,
Nupur
Nupur
Hi nupurs,
I have a similar scenario and a question: I only have a part of my design encrypted. And, when I do write_edif, that part gets separated into a second .edn-file, in accordance with the default security_mode setting, which is multifile.
Now my client gets the top-.edf-file and the encrypted .edn-file. He added both to a new project, but the encrypted .edn-file is not used during synthesis. He gets a critical warning:
[Project 1-486] Could not resolve non-primitive black box cell <name of encrypted vhdl module> instantiated as ...
I know I could just change the security_mode and get a single file as output, but I was curious if you knew how to deal with importing multiple netlist-files.
Thanks a lot,
Andrei
@luis.munoz hi,
I am working on zynq7020 customized board, I have created the complete video pipeline part in PL side . now I have to give this to my customer , my customer need to add some more logic into PL Side, But I cant directly give my PL block Design to them. when I am searching someone posted about the NETLIST, from that they extract the design and  add their logic into PL side. could u please explain WHAT and HOW can I generate my complete PL DESIGN NETLIST. if u have done this before could u please explain me.. u can contact me @ ramesha15390@gmail.com
WITH REGARDS
RAMESH
@theertharamesha
You can shared the synthesized netlist in the form of .edf of .dcp by using write_edif/write_checkpoint command after synthesis. Your customer needs to instantiate this file in the design with the other logic.
Anusheel
Helpful answer -> Give Kudos
thank you @anusheel,
I have generated the synthesized netlist with tcl command. now I want to test these netlist file whatever I have generated is correct?
for that I need to create a sample project with some logic and for that I need to instantiate my netlist. could you please tell how can I instantiate my netlist .
@theertharamesha
You will need to have a stub for this flow. Please refer below AR:
https://www.xilinx.com/support/answers/54074.html
Anusheel
I have followed the steps u have been mentioned . I have instantiated the .edf & Verilog stub file in my main design . but I am getting implementation error.
please look into the snap chat of the error message
with regards
ramesh
