fractal99
Help - Resource Sharing Enable/Disable by Module
I have a design that has inherited IP which requires resource sharing to be turned on.  However, for the code I have developed that is a separate module but part of the same overall project I want resource sharing to be turned off. How can I selectively do this in Vivado?
(FYI, I am using a Virtex 7).
jmcclusk
Mentor
Mentor
Unfortunately, resource sharing is only controlled by a synthesis command line option, and not a module property usable by block synthesis.  The only way I can imagine you can do this is to compile your inherited IP separately and include it into your project as a design checkpoint (DCP) file.    Or vice versa.   Compile your new IP separately without resource sharing and include it as a DCP.
brimdavis
@fractal99  "How can I selectively do this in Vivado?"
FWIW, Vivado 2017.x added some support for applying synthesis options/strategies to a given module/entity in the hierarchy; see Chapter 3, "Using Block Synthesis Strategies", of UG901 2017.4
Examples from UG901:
set_property BLOCK_SYNTH.<option name> <value> [get_cells <instance_name>]
  set_property BLOCK_SYNTH.MAX_LUT_INPUT 4 [get_cells fftEngine]
  set_property BLOCK_SYNTH.KEEP_EQUIVALENT_REGISTER 1 [get_cells mod_inst]
set_property BLOCK_SYNTH.STRATEGY {<value>} [get_cells <inst_name>]
  set_property BLOCK_SYNTH.STRATEGY {ALTERNATE_ROUTABILITY} [get_cells mod_inst]
Querying  BLOCK_SYNTH with list_property gives the following list of supported options:
BLOCK_SYNTH.ADDER_THRESHOLD
BLOCK_SYNTH.AUTO_PIPELINING
BLOCK_SYNTH.COMPARATOR_THRESHOLD BLOCK_SYNTH.CONTROL_SET_THRESHOLD BLOCK_SYNTH.EXTRACT_PARTITION BLOCK_SYNTH.FLATTEN_HIERARCHY BLOCK_SYNTH.FLATTEN_INSIDE_PARTITION BLOCK_SYNTH.FSM_EXTRACTION BLOCK_SYNTH.KEEP_EQUIVALENT_REGISTER BLOCK_SYNTH.LUT_COMBINING BLOCK_SYNTH.MAX_LUT_INPUT BLOCK_SYNTH.MUXF_MAPPING
BLOCK_SYNTH.PRESERVE_BOUNDARY BLOCK_SYNTH.RETIMING BLOCK_SYNTH.SHREG_MIN_SIZE BLOCK_SYNTH.STRATEGY BLOCK_SYNTH.USER_PROVIDED
Although RESOURCE_SHARING isn't listed in the above, it might be worth experimenting with "USER_PROVIDED" to see what exactly that supports.
I'd also try the PERFORMANCE_OPTIMIZED block strategy to see if that disables resource sharing:
set_property BLOCK_SYNTH.STRATEGY {PERFORMANCE_OPTIMIZED} [get_cells mod_inst]
-Brian
