jptalledo
Help with 2677 Error : Node XX of sequential type is uinconnected in block XX
I am getting a lot of 2677 errors for my char_buffer register.  if I comment the line:
assign sample_out = char_buffer; I don't receive any complains but I need to wire the char_buffer register to this output.
char_buffer get serial data from SPI.
My code is here:
module ext_ADC( CS, SCLK, sample_out, sample_update, SDATA, start, clock, reset);
  output  CS;   //Chip Select
  output  SCLK;   //Output clock to the ADC
  output [11:0] sample_out; //Current ADC Sample
  output  sample_update;   //flag for ready data
  input  SDATA;  //Serial data out from the ADC
  input  start;  //Start
  input clock;  //System clock
  input reset;   //System Reset
  localparam  IDLE_STATE  = 2'd0,  //State variables
      START_ADC = 2'd1,
      RUN_ADC  = 2'd2,
      PAUSE_ADC = 2'd3;
 assign SCLK = ~clock;  //Inverse of clock used to drive the ADC
 reg [1:0]  state = IDLE_STATE;    //State Machine variable
 reg [4:0]  ad_counter;                 //Counter used for ADC
 reg adc_conv;
 reg [11:0] char_buffer;
   reg [4:0]  bit_counter;
    reg start_bit;
    reg  update;
  reg prev_CS;
 assign sample_out= char_buffer[11:0];
 assign sample_update = update;
 //ADC Control Bits
 assign ad_start = (ad_counter == 6'd0) && (state == START_ADC);
 assign ad_data  = (ad_counter >= 6'd1) && (ad_counter <= 6'd15);
 assign CS = adc_conv;
 always @(posedge clock or posedge reset) begin
      if (reset) begin
   start_bit <=0;
         bit_counter <= 5'b00000;
   prev_CS <=0;
   end
  else begin
    if (prev_CS ==0 && adc_conv==1)
    start_bit <=1;
    else
    start_bit <=0;
    if (start_bit) begin
    bit_counter <= bit_counter+1;
    if (bit_counter==15) begin
     start_bit<= 0;
     bit_counter <= 0;
    end
         end
   prev_CS <= adc_conv;
  end
    end
      if (reset) begin
   char_buffer <= 12'd0;
   end
  else begin
   if (bit_counter >= 6'd3 || bit_counter <= 6'd16)
            char_buffer <= {char_buffer[10:0], SDATA};
    else
    char_buffer <= char_buffer;
    end
 end
 //AD Counter, increments the bit counter by 1 each clock cycle
   if (reset)
     ad_counter <= 6'd0;
   else begin
    if (ad_start || ad_data)    //*************
     ad_counter <= ad_counter + 6'd1;
    else
     ad_counter <= 6'd0;
   end
    end
  if(reset)
   adc_conv<= 1'd1;
  else begin
   if(state == START_ADC) begin
    adc_conv <= 1'd0;
   end else if(state == PAUSE_ADC) begin
    adc_conv <= 1'd1;
   end
  end
 end
 //State Machine
  if(reset)
   state <= IDLE_STATE;
  else begin
   case(state)
    IDLE_STATE:
     if(start == 1'b1)
      state <= START_ADC;
     else
    START_ADC:
     state <= RUN_ADC;
    RUN_ADC:
     if(ad_counter == 6'd15)
      state <= PAUSE_ADC;
    PAUSE_ADC:
     state <= START_ADC;
    default:
   endcase
  end
 end
endmodule
gszakacs
Professor
Professor
I tried this code and the only thing I see is that signal "update" is not
driven anywhere, so sample_update will be tied to zero.  However I don't
see the errors you report on sample_out.  Did you try to clean up your
project files and re-run synthesis?
-- Gabor
