05-06-2015 12:38 AM
I'm using Vivado 2014.3 and I have this warning when synthesizing my project:
[Netlist 29-101] Netlist 'aes128_fast' is not ideal for floorplanning, since the cellview 'aes128_fast' contains a large number of primitives. Please consider enabling hierarchy in synthesis if you want to do floorplanning.
What does it mean exactly? And how do I enable hierarchy in synthesis? I don't find any such setting.
Thx.
05-06-2015 12:59 AM
05-06-2015 12:57 AM - edited 05-06-2015 12:57 AM
Set the flatten_hierarchy to none in synthesis settings to preserve the hierarchy.
Deepika.
05-06-2015 12:59 AM
05-06-2015 01:34 AM
Refer below AR for information on -flatten_hierarchy switch:
http://www.xilinx.com/support/answers/52257.html
Anusheel
Helpful answer -> Give Kudos
05-08-2015 12:28 AM
Hi @binomex
Did that help?
Deepika.
05-08-2015 12:41 AM
Yes that helped. Sorry I've forgotten to mention that.
Thank you all.
02-26-2016 10:47 AM
HI,
In my design even if i keep the flatten heirarchy as none, i get the same warnning.
Kindly let me know what to do .
08-13-2019 06:27 AM
In my design also even if I set the flatten heirarchy as none, i get the same warnning.
Pleaese assist to what to do to resolve this warning.
08-14-2019 01:33 AM
Hi @knugent ,
You are replying to an old post.
Kindly create a new thread with your detailed query so community can help you better.
08-14-2019 02:18 AM
Sorry but this relates to same problem ssankar1 reported and no one commented on this matter.
08-14-2019 05:22 AM
Hi @knugent ,
This thread is already closed and marked as accepted solution.
Even if your issue is same you have to create a new thread so community can help you better.
10-16-2020 02:50 PM
Hi ,
I am also facing the same problem. Even after setting flatten hierarchy to "NONE". I ma getting same error which is " Design is not ideal for floor planning, since xxx contains a large number of primitives. Please consider enabling hierarchy in synthesis if you want to do floor planning".
Please suggest...
