jaxisjax
How can I get mux information?
Excuse me, I'd like to know how I can get mux information during the synthesis. After synthsis, I can only get lut information, and it seems like all the muxes were completely sliced into luts. Our inputs are .c or .v files, and I'd like to get some messages about anything related to mux such as mux-tagged luts. This seems a easy question but I really don't know how to do it as a new user of vivado.
Tags (4)
nupurs
Hi @jaxisjax,
Open the elaborated design, click CTRL+F and serach for MUX selecting options given in this snapshot:
Accept as solution if it resolved your query, give kudos if it helped you.
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
nupurs
Hi @jaxisjax,
Nupur
nupurs
Hi @jaxisjax,
If your query is addressed, please close this thread by marking the answer as "Äccept as solution" in the interest of other users.
Nupur
anusheel
@jaxisjax
You can search for MUX primitives in the generated netlist after opening the synthesized design. If you are not able to see any MUXs in the netlist then there is a possibility that the logic was pushed into LUTs.
For EX: show_objects -name search_MUX [get_cells -hierarchical -filter { PRIMITIVE_TYPE == MUXFX.others.MUXF7 } ] command will list all the MUXF7 cells in the netlist.
As I can understand from your post, you are working on HLS design. To check the MUX related logic in VIvado, open the elaborated design and check the MUX logic and use the cell name to search the synthesized design.
Anusheel
Search for documents/answer records related to your device and tool before posting query on forums.
Search related forums and make sure your query is not repeated.
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
