demetrio
How can I preserver a module which has no output signals in XST
I know it can add syn_pronune attribute in Synplify tools, but what can I do in XST
htsvn
Use a KEEP constraint.
This information is available in cgd.pdf that is available in the location ISE_Install\doc\usenglish\books\docs\cgd
This is under Xilinx Constraints Unit of cgd.
demetrio
Thank you for your advice
But my question is about when I want to keep a module not only one signal
The artical show me that the KEEP attribute is only applied on signal? How do you define a signal, a wire or a reg definition?
htsvn
Check the snapshot below to show how to keep a signal from being removed. As we see that the signals do exist in the netlist.
Use this as a part of your code.
attribute keep : string;attribute keep of sig_or2_2_z : signal is "TRUE";
attribute keep of sig_or2_1_z : signal is "TRUE";
demetrio
Sorry, you just misunderstand my question is how to preserver a module as its has no output for example
This module is almost not finished but need to evaluate its performance and area
Thank you again.
ywu
According to XST UG, syn_noprune attribute is automatically recognized by xst (see the attached snapshot). Does it not work for you?
Cheers,
Jim
Cheers,
Jim
