abdo.gaber
How to Generate the Design checkpoint file of block design based on Vivado 17.2
Hi All,
I have just update Vivado from 14.4 to 17.2. How to generate or get the Design checkpoint file (of block design) for the whole design?  I clicked on generate the block diagram. In Vivado 14.4, a single folder "synch1" is created and I can find my design_1.dcp in:
o<project location>\<project name>.runs\<design_1_synth_1\<design_1.dcp
However, in Vivado 17.2, several folders are created for every item in the design, and each has a .dcp file. Where I can find the design_1.dcp file for block design and not for wrapper. A snapshot has been added for the contents of project_1.runs
Best Regards
Abdo
thakurr
Hi @abdo.gaber
You need to select ooc per bd while generating the output products.
This way dcp of complete bd will be generated instead of individual dcp per IP. Actually you have selected ooc per IP, which creates dcp of individual IP in the BD.
For more information on the option refer the below link, page 77:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug994-vivado-ip-subsystems.pdf
Rohit
Rohit
thakurr
Hi @abdo.gaber
Rohit
Rohit
abdo.gaber
Hello Rohit,
really many thanks for your time and your support.
best regards
Abdo
