How to add Liberty Timing File (LIB) to Vivado and use it in my synthesis
I have a LIB file to add and use in my verilog design. It has PVT Characterization, relating input, and output characteristics, timing, power, noise.
How can I do this ?
Thanks in advance.
Ehsan
Re: How to add Liberty Timing File (LIB) to Vivado and use it in my synthesis
Hi @ehsan.aerabi
Vivado supports XDC files, which have some Synopsys SDC based timing constraints. You can refer to UG903 (attached below) to see what commands can be used:
 https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug903-vivado-using-constraints.pdf
