jcll
How to get images of RTL netlists using TCL ?
Hello !
I'd like to know if it is possible to get some images (either png, pdf, svg) of the RTL netlist, without using Vivado GUI, but simply by scripting TCL. How can we do that ?
Thanks in advance !
JCLL
thakurr
Hi @jcll
I think this is not supported outside GUI because this command needs schematic to be opened in order to get executed. As mentioned in the other thread you can add start_gui command after synth_design in your script to open the Vivado GUI with synthesized schematic and run write_schematic command. Afterwards you can use 'exit' or 'stop_gui' command to come back to tcl shell.
Rohit
Rohit
thakurr
Hi @jcll
I don't think you would be able to open the netlist file(created by tcl) with png,pdf,svg format as it is not supported. Supported extension would be .edn, edif,.v,.vg,.sv etc.
Please use any of these above (eg: write_edif <file_path>test.vg)
Rohit
Rohit
jcll
There is a "save as PDF" in the schematic viewer, accessible via contextual menu (right click).
It seems strange that there is no TCL command to get this PDF...
thakurr
Hi @jcll
When you click on "Save as pdf file" option then it will save the file in some location and corresponding tcl command will be executed:
write_schematic -format pdf -orientation portrait <location>/schematic.pdf
This pdf will have schematic representation of your design.
Rohit
Rohit
jcll
jcll
I have found the write_schematic TCL command, but there is no effect when running in TCL script outside the GUI. Is there something I am missing ?
thakurr
Hi @jcll
Rohit
Rohit
