Visitor yash047
How to initialize an array of record in VHDL?
I'm initializing an array of record which also contains a string. I'm getting an error HDLCompiler:806 Line 109: Syntax error near "text_passages" (Last line in the code below). What's the correct way of initialization?
type text_info is
    record
        text : string(1 to 15);        x: integer;        y: integer;
    end record;
constant init_text_info: text_info := (text => "               ", x => 0, y => 0);
type text_info_array is array(natural range <>) of text_info;
My declaration and initialization is as follows
signal text_passages : text_info_array(0 to 1) := (others => init_text_info);text_passages(0) <= (text => "This is a Test.", x => 50, y => 50))
text_passages(0) <= (text => "This is a Test.", x => 50, y => 50);
Re: How to initialize an array of record in VHDL?
hi @yash047 ,
signal assignments should be made after the keyword begin.
please check the image.
i added one more text (hello world) and simulated.
regards,
reshma
hi @yash047 ,
regards,
reshma
Visitor yash047
That was correct, I did signal assignment outside of bgein.
