Visitor wanhafizzul
How to merge optional output register into BRAM
Hi everyone.. i want to ask why the optional output register cannot be merged into the BRAM.
The runme.log file shows the messages as below:-
INFO: [Synth 8-4480]---(implemented as a block RAM) might be sub-optimal as no optional output register could be merged into the block ram. Providing additional output register may help in improving timing.
Thank you.
Scholar dpaul24
Re: How to merge optional output register into BRAM
@wanhafizzul,
Did you "check-out" the box beside Output Registers option while generating the FIFO?
If you don't tell the FIFO gen to add the output register then it will not be added.
FPGA enthusiast!
All PMs will be ignored
Hi @wanhafizzul
Are you using Block memory generator IP or inferring BRAM using RTL code?
Deepika.
Visitor wanhafizzul
We are inferring BRAM in RTL following the user guide.
Visitor wanhafizzul
This is my simplified version.
process(Clk) is begin
if falling_edge(Clk) then
if wrEn then
ram(to_integer(wrAddr)) <= d_b;
end if;
mem <= ram(to_integer(wrAddr));
end if;
end process;
/* Add BRAM optional output register. */
if wrEn then
i0_mem <= mem;
end if;
end if;
end process;
q_b <= i0_mem when (sel_wr = "00")
Participant fvandesa
Any follow-up on this?
I have the same question. For some reason I can't infer a BRAM with output registers.
Frank
hi @fvandesa ,
This is an old post.
Please create a new thread with your query so community can help you better to resolve it.
hemangd
