How to reduce Synthesis and Implementation time in VIVADO?
Deal all,
I'm trying to reduce the Synthesis and Implementation time in VIVADO.
and I found some article from here. https://www.xilinx.com/support/answers/62215.html
But I can't find where exactly these options existed in VAVADO 2014.4.1.
  •  Use the "-quick" option.
    Running Vivado Synthesis with the -quick option will greatly reduce run time as there are little or no optimizations performed.
  •  Use the "RunTimeOptimized" directive.
    The RunTimeOptimized directive is another method of reducing the optimizations performed by Vivado Synthesis.
    The "synth_design -help" option returns the following information:
Would you please let me know more exactly?
Re: How to reduce Synthesis and Implementation time in VIVADO?
Hi @sylee119,
Run "synth_design -help" in tcl console of Vivado and you will get the options and directives to use with this command.
i.e. synth_design -effort_level quick
i.e. synth_design -directive runtimeoptimized
Note: Some run time improvements come at the expense of quality of results. This is not always the case, but turning off various optimizations will improve the run time of synthesis.
hemangd
hemangd
Don't forget to give kudos and mark it as accepted solution if your issue gets resolved.
Hi @sylee119,
hemangd
hemangd
@sylee119
Synthesis run time depends upon the design complexity and RTL coding. Are there any big loops in the design?
Also, I can see that you are using an old version of Vivado, check the design in latest Vivado version once as we have fixed few run time related issues in the past.
Anusheel
