How to retain module input/out ports and not being optimized out using precision sythesis?
According to  AR# 11231,  I put the following pragma line above my module definition in a verilog file and intended to keep the ports not being ptimized out:
//pragma attribute comp_inst hierarchy "preserve";
module my_module (.....
I am using precision to synthesize my verilog design. But it seems not making any differences. In the synthesized file, the ports of my_module still not present. Does anyone know what I might have been doing wrong?
Is there any other ways to keep ports or wires in the syhthesized result so I can pull them out to a debug core? Thanks.
Re: How to retain module input/out ports and not being optimized out using precision sythesis?
Hi @zhua ,
Try to put KEEP_HIERARCHY property in constraint file. Check page no.137 of below link:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/cgd.pdf
Raj
Hi Raj,
Is this the right syntax?
(* KEEP_HIERARCHY = "{TRUE}" *)
module my_module (......
I am running precision now and see how it goes.
Zhi
Hi @zhua ,
Instead in RTL, apply it in UCF:
INST “instance_name ” KEEP_HIERARCHY={TRUE|FALSE};
Raj
Thanks Raj. I put "(* keep_hierarchy = "yes" *)" at the front of the module instantiation. It see the hierary is kept in the sythesized file now. But the ports are still optimized out. I tried to add "(* S = YES *)" at the front of module input/output signal definiton. Precision did not like it and gave an error.
@zhua
Looks like you are using 3rd party tools, can you please use the 3rd party's forums to get details on its usage.
Anusheel
