How to synthesize without optimization in vivado?
Hello Guys
I have synthesized logic that have a buffer to use delay.
For example,
module buffer(output out, input in);
buf b1(out, in);
endmodule
or
module nbuffer(output out, input in);
not n1(w1, in);
not n2(out, w1);
endmodule
But buffer converted to wire in optimization.
I want buffers to be kept.
@grimlk
Try using DONT_TOUCH attribute to preserve these cells: (* DONT_TOUCH = "yes" *)  wire w1;
Anusheel
Search for documents/answer records related to your device and tool before posting query on forums.
Search related forums and make sure your query is not repeated.
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
@grimlk
Anusheel
Hi@@grimlk,
Please refer UG-901, page 45 and see if it helps.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug901-vivado-synthesis.pdf
Asit
