How to synthesize without optimization in vivado?
Hello Guys
I have synthesized logic that have a buffer to use delay.
For example,
module buffer(output out, input in);
buf b1(out, in);
endmodule
or
module nbuffer(output out, input in);
not n1(w1, in);
not n2(out, w1);
endmodule
But buffer converted to wire in optimization.
I want buffers to be kept.
Re: How to synthesize without optimization in vivado?
@grimlk
Try using DONT_TOUCH attribute to preserve these cells: (* DONT_TOUCH = "yes" *)  wire w1;
Anusheel
Helpful answer -> Give Kudos
@grimlk
Anusheel
Hi@@grimlk,
Please refer UG-901, page 45 and see if it helps.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug901-vivado-synthesis.pdf
Asit
