Visitor raraz15
How to use a library?
Hello, I have to use Q Format Floating Point Arithtmetic in my project. I have limited knowledge on Libraries and packages  and I searched the internet for some time and asked my professors about it. No answers.
I found the Floating point package user’s guide of David Bishop and I try to do as in the description. So here is the question
I find the relevant files, but,
  1. I do not know what to do with these files? (Library Compiling, IEEE folder... so confused)
  2. I do not know how to use these libraries/packages in my VHDL code.
(I use Xilinx ISE 14.7 by the way)
Thanks a lot in advance :)
Re: How to use a library?
Visitor raraz15
I am trying to follow the instructions, but the guide doesn't specify anything about the Floating package, (I can try Fixed Point also as I don't want to fail this class )
Let's say I try the Fixed Package, the files that are mentionned in the vivado-logic-simulation.pdf are nowhere to be found, not on the computer, not on the internet, except David Bishop's  and his file names are different than in the vivado-logic-simulation.pdf.
After being directed to https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug901-vivado-synthesis.pdf, page 214 it is said
"First, compile the Fixed Package in the IEEE library. This package is available in the file: fixed_pkg_2008.vhd, in the scripts/rt/data/ directory in your Vivado install. This package is not precompiled in Vivado, so you must compile the file in your design.
• To compile the file using the GUI, copy the fixed_pkg_2008.vhd file from the Vivado build directory to your personal directory. Then in the Vivado IDE, add the fixed_pkg_2008.vhd file to your project, and make sure that it is compiled into the IEEE library.
• To compile the file using Tcl commands, type the following on the Tcl Console:
add_files –norecurse /fixed_pkg_2008.vhd
set_property library ieee [get_files /fixed_pkg_2008.vhd]
read_vhdl –vhdl2008 ./my_design.vhd
launch_runs synth_1 –jobs 4
wait_on_run synth_1
open_run synth_1 –name synth_1
" I honestly do not know what to do at this point. Can anyone give me a working link for the library and descriptions for how to compile and use that library in Xilinx ISE 14.7?
