I don't understand "Xst:790-Index value(s) does not match array range, simulation mismatch." message.
I don't understand the following warning message...
My coding is as following
     type stc_scid is array(0 to 19) of std_logic_vector(5 downto 0);
     type stc_sad is array(0 to 19) of std_logic_vector(9 downto 0);
     type stc_tpl is array(0 to 19) of std_logic_vector(5 downto 0);
     type stc_stl is array(0 to 19) of std_logic_vector(9 downto 0);
     signal SCID : stc_scid;
     signal SAD : stc_sad;
     signal TPL : stc_tpl;
     signal STL : stc_stl;
     variable stc_cnt : integer range 0 to 19 :=0;  -- stc_cnt can't have values bigger than 19
      SCID(stc_cnt) <= STC(5 downto 0);
      SAD(stc_cnt) <= STC(9 downto 0);
      TPL(stc_cnt) <= STC(5 downto 0);
      STL(stc_cnt) <= STC(9 downto 0);
I think, there is nothing wrong.
I don't understand why the warning message is occured....
Please tells me what is wrong.....
Message Edited by gekuls21 on 04-21-2009 06:12 PM
Message Edited by gekuls21 on 04-22-2009 01:07 AM
Professor
Professor
How did you define "stc_cnt"?  Can it take on values greater than 19?
-- Gabor
Of cause, I defined stc_cnt  like following
Take a power of 2 and it will work. (round to a power of two).
0 to 19 can be implemented in real hardware...
0 to 19 can't... of course...
This is due to accessing an array with length less than a power of 2.
This simulation mismatch message is sometimes not valid. For example, there is an array of 0 to 9 and a counter is used to access the array but the counter logic synthesized is shown to be implemented with a count limit, which is 9. A simulation mismatch message can still be seen despite there won't be simulation mismatch. In this case this message is not valid. I have tested with the new parser XST-2 and this simulation mismatch is not there for the above example given.
If you have hundreds of these warnings, you may want to filter these messages by Edit> Message Filters.
Cheers,
Anonymous
Not applicable
Thanks  dear...! It works..
I am a noob in vhdl,
I am also getting same type of warning : line 129: Index value(s) does not match array range, simulation mismatch.
--declaration of MAS & MASS SIGNAL
SIGNAL MAS : STD_LOGIC_VECTOR(15 DOWNTO 0);
SIGNAL MASS : STD_LOGIC_VECTOR(3 DOWNTO 0);
FOR x IN 0 TO 3 LOOP
     MAS(x)<=MA2(x);
END LOOP;
FOR I IN 4 TO 15 LOOP
     MAS(x) <= '0';
END LOOP;
      MASS(x)<=MAS(x+DIFI);   --the warning occurs over here
END LOOP;
Please tell me what is wrong ...
I dont know why the warning came ...
