Visitor thweight
I2C for my ARTY S7
Hi Everyone,
I am new to FPGA's and this is my first post. I hope this is in the right place.
I am trying to get i2c working on my ARTY board using (of course) the SDA and SCL pins and Vivado 2018.1 (64 bits).
All I want is to talk to one slave with no other masters. So I don't have to worry about making SCL open collector. But the SDA is another matter.
I have this code for writing to the inout sda port.
         if(l_sda_tx = '0') then
            sda <= '0';
         else
            sda <= 'Z';
         end if;
When I synthesize the program, I get a critical warning:
"[Synth 8-5799] Converted tricell instance 'U0i_0' to logic  ".
I googled this and learned that (with an older version of Vivado) I need to switch from "OOC" to "Global".
This is where I hit a brick wall. I found several explanations of how to do this but none seem to apply to my version of Vivado.
Thank you in advance for your help.
Re: I2C for my ARTY S7
@thweight
I don't get where you are hitting the brick... with the ooc - > global or with the IO buffer?
As already showed by dpaul24 you see how to do this manually... or by Vivado automatically when you use the signal endings *_i, *_o and *_t...
In addition, although dpaul24 did not state it explicitly the line:
    I  => sda_o,  -- Bufferinput
means that sda_o is a constant and '0'.
Concerning your remark "...one slave with no other masters. So I don't have to worry about making SCL open collector..."
Be warned: There are I2C slaves which do clock stretching to delay a response... typically ADC based I2C components which need some time.Please check as well: https://www.i2c-bus.org/clock-stretching/
If your component drives a '1' (instead of a 'Z' which results due to the I2C pull-up resistor 'H') and your I2C slave stretches the clock by pulling it low -> you will go to the limit of your FPGA output driver. No a really nice behavior... will say, even if you do not care about clock stretching don't drive the SCK directly but by a open collector (iobuf).
Cheers
Goran
Scholar dpaul24
@thweight,
If the tri-state buffer connection of the SDA is worrying you the try using the Xilinx primitive IOBUF.
SDA_IOBUF_inst: IOBUF
    generic map(
    DRIVE      => 12,
    IOSTANDARD => "DEFAULT",
    SLEW       => "SLOW"
    port map(
    O  => sda_i,  -- Buffer output
    IO => sda_io, -- Buffer inout port(connect directly to top-level port)
    T  => sda_t   -- 3-state enable input,high=input,low=output
FPGA enthusiast!
All PMs will be ignored
@thweight
Cheers
Goran
Visitor thweight
Is it possible to accept two replies as Solutions?
