IBUFDS module declared in IP core wizard generated module
Dear all,
I am using ISE 12.2 and design kit SP605 for GTP applications.
The GTP Transceiver wizard generated a module and it will use external SMA clock input. The differential SMA input will be buffered by a IBUFDS module based on my understanding.
During the thynsis, the XST tool reported the module is not delcared.
I tried to delcare the component but strangly the module name IBUFDS is shown in brown colour and it is the same in the original wizard generated core.
So how can I solve this problem? Is there any head file or library I should included in the design?
Thanks to all in advance!
Tags (2)
Re: IBUFDS module declared in IP core wizard generated module
The problem is solved by using library UNISIM
library UNISIM
use UNISIM.Vcomponents.ALL
And there are some non-synthesable componets in the GTP transceiver because the generic part needs to be set to 0 for synthesis and 1 for simulation.
library UNISIM
