moon5756
IBUFGDS not recognized as IO buf
I have a IBUFGDS instantiated like below,
IBUFGDS #(.DIFF_TERM("FALSE"),
    .IOSTANDARD("DEFAULT"))
    IBUFGDS_inst(.O(I_HCLK),
    .I(I_HCLK_P),
    .IB(I_HCLK_N));
I synthesized the design with Synplify Premier and open the synthesized design in Vivado(2018.3), and found that this IBUFGDS_int is not synthesized as IBUFDS primitive.
I think this leads to Vivado not recognizing I_HCLK_P as a differential clock. Instead Vivado recognized I_HCLK_P as single-ended.
I think the problem is that I manually added IBUFGDS.v file that has a module IBUFGDS.
Not sure what this file is though...
My question is that
1) Is IBUFGDS a verilog primitive so that I don't need a separate IBUFGDS module definition?
2) Then, what is this IBUFGDS.v that seems like Xilinx generated 10 years ago?
Thanks in advance.
hongh
IBUFGDS.v file you imported seems to be a simulation model file and you don't need to add it into Synplify project.
You can just instantiate IBUFDS primitive in your source code directly.
IBUFDS #(
.DIFF_TERM("FALSE"), // Differential Termination
.IBUF_LOW_PWR("TRUE"), // Low power="TRUE", Highest performance="FALSE"
.IOSTANDARD("DEFAULT") // Specify the input I/O standard
) IBUFDS_inst (
.O(O), // Buffer output
.I(I), // Diff_p buffer input (connect directly to top-level port)
.IB(IB) // Diff_n buffer input (connect directly to top-level port)
hongh
IBUFDS #(
) IBUFDS_inst (
