chughsumit
ILA probes optimized
I inserted ILA probes after synthesis in netlist and able to implement anf generate bitfile.
In next synthesis run, i do had some design changes and some nets were optimized and tool reported error during opt_design that ILA probes not found . So I need to remove all the unconnected probes from the ILA debug port probes in GUI mode after opening synthesized design netlist and re-run implement- opt_design.
Is there a command or property that make sure it removes all unconnected probes and continue opt_design..? So that the tool dont report error for these ILA probes nets not found/unconnected.
Please help share.
thanks,
Sumit
vemulad
There is no tool switch/option to allow unconnected channels of ILA core.
Check this related thread http://forums.xilinx.com/t5/Implementation/Is-it-possible-to-build-with-unconnected-debug-channels/td-p/536795
Deepika.
Deepika.
