Voyager
Voyager
ISE 14.7 RTL Schematic how to expand nets?
I've seen different display in numbers of my nets, I could only see the net if I double-click on the net first thing RTL Schematic view, otherwise, it shows as disconnected, could not find a way to expand.
Another thing is, as example I have 6-bit output, in RTL Schematic/Technology View, I could only find a single register (fdse); all other logics are invisible.
From simulation, signal behavior is correct, and it has sequential logic on them, should not be synthesized away. I've tried adjusting "keep hierarchy", no help.
What's better way to do this?
Thanks for comment,
Hi @legendbb,
You can make use of PlanAhead for better view.
Arpan
Arpan
Hi @legendbb,
Arpan
Arpan
Voyager
Voyager
Thanks with watering eyes.
Hi @legendbb,
I am not getting:
Do you mean optimize away?
Arpan
Arpan
Voyager
Voyager
What I meant to say is nets I was trying to find, absolutely exists after synthesis.
I've got what I need in RTL Schematic in PlanAhead. I had been using Vivado for years, due to legacy project rolled back, totally forgot those tricks. Thanks for reminding.
