Visitor catalineacsu
ISE RTL Flat vs Hierarchical view
I have a big project done with ISE. When I expand the top level block of the schematic, it expands everything down to the low level detail without showing the next hierarchical level. It is thus impossible to manage.
Here is what I get when I double click the top level block:
Here is an example (from another project) of what I would like to see:
Is there a setting that makes the switch between the two display modes?
Catalin
Tags (4)
Re: ISE RTL Flat vs Hierarchical view
@catalineacsu,
In the synthesis process properties, Try to set the keep hierarchy switch to Yes,
This way your hierarchy will be maintained and you will see your desired view.
Syed
Hi @catalineacsu,
You can use keep_hierarchy as either soft or yes to get the desired view.
If you want the hierarchy to be maintained even in implementation then use keep_hierarchy as yes else use soft.
Arpan
you can find XST options here
https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/pp_db_xst_synthesis_options.htm
https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/ise_c_using_the_design_views.htm
Thanks and Regards
Balkrishan
Thank you all for the replies. Unfortunately I already tried this option before posting the message. See below my settings.
Attached is the project (no secret, as it is an open source one). I would really appreciate if you can look further into this.
Hi guys,
any other thoughts on this?
Observer c_bauer
Same here. If there is a solution, I'd be happy to hear!
best,
Chris
