Visitor 463717263
always @ (posedge clk or negedge rst)
begin
if (!rst)
sram_sel<=0;
else
din_en_reg<=sram_din_en;
end
always @ (posedge clk or negedge rst )
begin
if(sram_din_en)
begin
if(addr1_reg==8'd63)
begin
addr1_reg<=32'h0;
sram_sel<=~sram_sel;
end
else
addr1_reg<=addr1_reg+1;
end
else
addr1_reg<=32'h0;
end
begin
if(sram_din_en)
begin
if(addr2_reg==8'd63)
begin
addr2_reg<=32'h0;
end
else
addr2_reg<=addr2_reg+1;
end
else
addr2_reg<=32'h0;
end
error The logic for < addr1_reg > does not match a known FF or Latch The template .can you tell me how to solve this problem?
Historian
Historian
Re: ISE RTL
Your sensitivity list is "always @(posedge clk or negedge rst)" this means that the block will be evaluated on the rising edge of the clock or the falling edge of rst. However, you don't have an if (!rst) clause in the block itself, which completes the definition of a flip-flop with active low asynchronous reset. Without this, the tool sees this as flip-flops with two different clocks, which doesn't exist.
Avrum
Historian
Historian
Re: ISE RTL
Avrum
Visitor 463717263
Re: ISE RTL
thanks,Avrum.
what i want to do is a ping-pang RAM structure.when read SRAM1,write SRAM2.when read SRAM2,write SRAM1.what should i do to realise it?
floyd
Visitor 463717263
Re: ISE RTL
module sram_ctr(clk,
rst,
data1,
addr1,
ce1,
we1,
oe1,
data2,
addr2,
ce2,
we2,
oe2,
sram_din,
sram_din_en,
sram_dout,
sram_dout_en);
//port
input clk,rst,sram_din_en,sram_dout_en;
input [31:0] sram_din;
output [31:0] sram_dout;
inout [31:0] data1,data2;
output [31:0] addr1,addr2;
output ce1,we1,oe1,ce2,we2,oe2;
//intra port
reg [31 :0] sram_dout;
reg [31:0] addr1_reg,addr2_reg;
wire [31:0] addr1,addr2;
wire [31 :0] data1,data2;
wire ce1,we1,oe1,ce2,we2,oe2;
reg sram_sel;
wire [31:0] data_reg;
reg din_en_reg;//延时din_en_reg
//复位
begin
if (!rst)
sram_sel<=0;
else
end
//设置写ram地址
always @ (posedge clk )
begin
if(sram_din_en)
begin
if(addr1_reg==8'd63) //限定每次传输额度
begin
addr1_reg<=32'h0;
sram_sel_flag<=~sram_sel; //切换读写标志,达到限定传输额度就交换
end
else
end
else
addr1_reg<=32'h0;
end
//设置读ram地址
begin
if(sram_din_en)
begin
begin
addr2_reg<=32'h0;
end
else
end
else
addr2_reg<=32'h0;
end
//乒乓读写ram逻辑
assign ce1=1'b0;
assign ce2=1'b0;
assign we1=(!sram_sel&&sram_din_en)?(~clk):(!sram_din_en)?1'b0:1'b1;
assign oe1=( sram_sel&&sram_din_en)?clk:1'b1;
assign we2=( sram_sel&&sram_din_en)?(~clk):(!sram_din_en)?1'b0:1'b1;
assign oe2=(!sram_sel&&sram_din_en)?clk:1'b1;
assign addr1=(!sram_sel&&sram_din_en)?addr1_reg:addr2_reg;
assign addr2=(!sram_sel&&sram_din_en)?addr2_reg:addr1_reg;
assign data1=(!sram_sel&&sram_din_en)?sram_din:8'hzz;
assign data2=( sram_sel&&sram_din_en)?sram_din:8'hzz;
assign data_reg=(!sram_sel&&sram_din_en)?data2:( sram_sel&&sram_din_en)?data1:sram_din;
begin
if (sram_dout_en)
begin
sram_dout<=data_reg;
end
end
endmodule
here is my code ! where is the problem!
Historian
Historian
Re: ISE RTL
It's not formatted, and as such is impossible for a human to read.
