ISE WEBPACK FSM problem
I have a problem with finite state machine using ise webpack 14.7 .
I have fine working devices that are my Rx and Tx box .
I have merged Tx and Rx vhdl code and the result instead a state machine of 39 states is a rom 39X1 .
Why ?!?
If I stop the route of code to reset the sysntetizer recognize it like a 39 states machine BUT WARN me that it don't reach the others 38 states.
Resolved.
It was a local logical feedback in a single state of FSM that clearly didn't like to syntetizer.
You post makes little sense
Can you post the code and try and better explain the problem?
I'll try to explain better.
I have two piece of vhdl code that describes two finite states machines (Rx and Tx) that works fine.
If I try to merge in a one vhdl code with one state machine, doubled size respect ones,  I get the problem that don't recognize like a fsm but like a rom.
The merging is done by appropriate change and i don't get any error or extra warning.
Is there same limit for states machine?
Please post your code as an attatchment,
there is no practical limit to state mahchine sizes outside the size of the chip.
This sounds very much like a codding feature,
Post the code and we can try help.
Post the failing and passing code, along with the test bench you have please.
Resolved.
@maxim that will do it.
Well found,
you might want to close the case and give Kudos as you feel
