In Vivado 2015.2 can not find cmd Xilinx::ultrafast::report_io_reg
I am following below answer sheet to do report_io_reg
https://forums.xilinx.com/t5/Vivado-TCL-Community/How-to-Report-IOB-Register-Packing/td-p/500018
But, after I enter cmd in Vivado 2015.2 with the implemented design
  • xilinx:: ultrafast::report_io_reg
I got below result.
Does anyone happen to know why I can't get the information related to I/O ports and packed reg in my design?
Re: In Vivado 2015.2 can not find cmd Xilinx::ultrafast::report_io_reg
zan_zhan@amat.com
New versions of Vivado have several ways to check if register are packed into the IOB.  For example, your can use report_datasheet and Tcl commands shown in <this> thread.
For v2015.2 Vivado, you might be able to use report_io_reg after downloading it from the Xilinx Tcl store as shown in <this> thread.
Mark
回复: In Vivado 2015.2 can not find cmd Xilinx::ultrafast::report_io_reg
You need to open a synthesized or implemented design and then run this command.
There's no I/O information without any design loaded to memory.
zan_zhan@amat.com
Mark
Below are the steps I did to run "Xilinx::ultrafast::report_io_reg"
1.in linux, open Xilinx 2015.2 vivado
2.open the implemented design
3.install "Ultrafast Design Methodology" in tcl store
4.run "Xilinx::ultrafast::report_io_reg" in tcl console
Is the snapshot captured after you open the implemented design? If so, the design is not actually loaded.
Once you click "Open Implemented Design" from Flow Navigator on the left pane and it's done, you should see IMPLEMENTED DESIGN shown in the upper banner. See the following figure for example.
I got the correct report after clicking "open implemented design"
Thank you very much!
BTW, About the info column in the report, I saw three different content in info column ( no input FF, no output FF and blank)
the blank means this signal has iff or off packed into IOB. <-- is this correct?
I think it's true if you see either ILOGIC or OLOGIC column is marked for blank info ports.
