Observer dbanks12
Incremental Synthesis? - 2017.1
Does Vivado 2017.1 support some sort of incremental synthesis? I am referring to synthesis not implementation. I ask this because UG835 lists the "-incremental" option for "synth_design".
Re: Incremental Synthesis? - 2017.1
@dbanks12
Yes, this feature is still under road-map and production support is not yet available in 2017.1.
Anusheel
Helpful answer -> Give Kudos
@dbanks12
Anusheel
Observer dbanks12
Interesting. Thank you @anusheel.
